Old 07-25-2007, 09:20 AM
LoveMySeacraft LoveMySeacraft is offline
Default Re: Gas Tank Moved!!! Help!
If its foamed in place, as you said, and has moved...Then use up as much of the fuel as possible, or pump it out, move it back into position & then foam the rear, and any other void spots. I would'nt try to float it back in place with water. Using 2-part(A/B) foam will displace any existing water areas & then that tank shouldn't budge any more. Most commonly used foam is what they call "2-pound" foam. Thats because its less money. But I prefer using the more expensive "4-pound" foam, because its much denser & stronger. The tank ain't going nowhere with 4-pound.
