Old 08-18-2007, 06:22 PM
askipper3 askipper3 is offline
Default Re: Been doing some work on my 20sf!!!!
Im going to install the bait tank under the rocket launcher. 27 gallon kodiack.
And the scuppers work quite well, about 80 percent of the time.
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150
http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg
Old 08-21-2007, 01:22 PM
HatTrick HatTrick is offline
I have an '86 twin to your boat and I'm a little disappointed with the ball scuppers. I wonder if the transom angle doesn't allow the ball to sit properly.
'86 20 ft CC with 4-stroke 150 yamaha
Old 08-23-2007, 09:01 PM
Hmmm.....well, is water coming in....or just not draining out?
Old 08-23-2007, 10:25 PM
dcobbett dcobbett is offline
HatTrick,
Just a suggestion, but try adding a wegdge type device under the inside top of the ball cage. The intent is to not let to ball float as high or as much towards the stern as it can without the wedge.
I saw this approach on Roger's MA and he thinks it's a good modification. I think he uses small strips from the circumference of a piece of PVC pipe cut to a lenght that will fit inside the cage piece.
