Old 08-21-2007, 09:13 PM
Default Re: Water Pressure vs Water Temp gauge
muddy maybe u shouldnt listen to me because i cant get mine running right at all.. its coming off the boat.. ive had it with that supposed "turn key" engine.
Old 08-21-2007, 10:32 PM
...after the poppet opens (about 3k rpm) the pressure should drop to about 8-12 psi and stay there all the way thru WOT
Mine ('92 Merc 150 carb) drops from about 38-40 psi to about 16-20 psi at between 2800 - 3400 rpm when the poppet opens and then stays pretty constant to WOT. If your pressure drops below 8 psi at any time you have a problem.
Fr. Frank says:
Currently without a SeaCraft
Old 08-21-2007, 11:30 PM
mine is an 84 2.4L. so maybe thats the difference? yours is a 2.5L i beleive
Old 08-22-2007, 08:54 AM
doug7488 doug7488 is offline
Isn't the water pressure somewhat lower in the 2.5's as opposed to the 2.4's?
Old 08-22-2007, 07:02 PM
ya got me on that one.. muddy have u been to www.screamandfly.com yet??
Old 08-22-2007, 07:15 PM
evan you get it going yet?
Old 08-22-2007, 11:41 PM
i forgot ur other name doesnt work. ive been sending u pm's.
but no its worse than before after i got the water pump changed by a pro.
Old 08-23-2007, 10:39 PM
damn well i think it may be time for another motor I'll keep my eye out for you!! Yeah I dont know why my other log in is not working???
Old 08-24-2007, 12:18 AM
well i wanted to know if u have a 20 or 25 inch shaft on ur motor? i think my problem is in the water pump base or something because after i had it professionally replaced i still have water coming up out of where the shift shaft is. and now i got water coming out of only one of my above water exhausts. i think i gotta take it all apart again like it was when u saw it...
Old 08-24-2007, 02:20 AM
muddywater muddywater is offline
Yeah Blue, I have been to S&F. I did some reading there and at Iboats which confirmed what you guys said. If I really had some $$ to throw at it, I might try to hop up the engine while I was at it, but I have been throwing cash at the boat like it is going out of style and I haven't even really gotten started. My transom is mulch and my deck isn't far behind. I just wanted to take it out a couple times before I really chop it up.
-Muddy
