Old 08-28-2007, 05:35 PM
Default Re: transom rebuild
Hermco - When you leave the 3" border of old transom . . . do you dig out the old wood around the edges or just leave it be?
Seems like if the perimeter wood is dry and in marginal shape it'd be "ok" to leave it be . . . correct? or should you just dig out everything and fit a bunch of pieces in like a jig saw puzzle?
Old 08-28-2007, 08:18 PM
Fishjack Fishjack is offline
For best results I would get it all out and if you cut the top cap you can slide the new core in as one piece and not have to "jigsaw" puzzle it it.
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
Old 08-28-2007, 09:05 PM
hermco hermco is offline
Removing the core from the outside saves you from cutting the cap or liner.
Old 08-28-2007, 09:20 PM
Hermco - are you saying that pros leave the old wood in there?
Old 08-28-2007, 10:18 PM
david76 david76 is offline
did yall see thatfish icaught over the weekend? its in the fish catagory
Old 08-30-2007, 09:57 PM
Protek9543 Protek9543 is offline
youngone
stranger
Reged: 08/01/07
Loc: howey in the hills florida Re: transom rebuild [Re: Bigshrimpin]
#53618 - 08/28/07 10:18 PM Edit Reply Quote
My first guess would be you did'nt catch it on this boat?
3 Boats / 1 Floats
Re-fit or Reef-it
Old 08-28-2007, 10:45 PM
I don't know how the pros do it. I cut the outside skin approx 3" from edge,remove old bad core,dig out any wet,rotted,loose core from edge,add 2 1708 biaxial to inner skin,backfill edges with putty,glue on new core with a 1.5 oz mat,add outside laminates and finish.I do not reuse the old skin.
Old 08-29-2007, 09:10 AM
jobu jobu is offline
If you leave three inches around perimeter...how do you get it in? (curious...planning a rebuild this off season).
I am a carpenter with a little glass expirience, I want to put on a bracket and fill in the transom. I am only apprehensive about doing the detail work like the baitwell and the edges and hatches. I will research this site further when the time comes...seems there is alot of good info on here.
But when it comes time to finisg the glass work...do you sand down and skim with filler to make it smooth?? (whats a quick discription of a good method)
thnx joe
Old 08-29-2007, 09:30 AM
For the answer to your first question read the post above you again but this time more carefully. The answer to your second question is yes. The quick description would be "Lots of sanding and fairing."
Old 08-29-2007, 12:42 PM
thnx joe
Joe - when building a baitwell . . . build a mold out of MDF and you don't have to deal with all the finish work. When you design the part make sure that your seams are on flat surfaces (b/c it's much easier to fair and finish flat areas.
