Here are some before and after shots after using Polyglow on hatch, cabin top & sides. It's MUCH easier than waxing, and the gloss is better than I expected! Just apply the liquid to the chamois in the kit and wipe the surface. Wait a minute or so for it to dry, and then apply another coat. I put on a total of 6 coats. Can put on a couple more coats after 6-12 months. PowerBoat Reports says it'll last a year in the S. Fla. sun, so we'll see.
The kit contains a very strong cleaner and a white 3M scrubbing pad that will take off dirt & oxidation (and the Polyglow coating!) so need to start at top and work down to avoid spots from the cleaner. Surface needs to be really clean because whatever is on it will be there for a year or more after coating! The milky-looking stuff is evidently a clear urethane coating, similar to clear coat used on cars these days. Although I've waxed the hull several times, I have never waxed the cabin top or hatch in the 32+ years I've owned this boat, since folks occasionally walk on it with wet feet and I was concerned about slips & falls. No one has slipped in all that time, and as you'd expect the gelcoat is fairly porous and just about worn thru, so time to either protect it or paint it, and I'd rather USE the boat than spend time painting it! ![]() ![]() ![]() ![]() Need to redo bootstripe next so I can coat the hull. Think I will try Signature paint, Chuck. The Interlux Interpoly I used about 1990 hasn't held up too well. Denny
I've read about poly glow, but is it only on line or can you find it in boating stores?
GARY 76 SEACRAFT CC INBOARD |
I got the kit from local Boat Owners Warehouse for about $60; BOW has a web site from which you could probably order it. You can also call poliglow at 800-922-5013, who should be able to provide name of nearest dealer or sell it to you directly. They're located about 60 miles from here in Ft. Pierce, Fl.
