Old 09-07-2007, 10:15 PM
Default Re: Yamaha 130 oil problem
I had my 130 go through different oil tank issues (remote tank / tank on the motor). the pump on the remote tank died once, replaced that and then the main pump shorted out. I would think that the linkage is not properly attached between the carb and the elec oil pump, not letting the oiling occur simultaneously with the throttle or the remote tank pump is the wrong pump-maybe for the V-6 which needs more oil. The sensor on the small tank I think only goes off when it's low not too high. Hope that helps.
