Old 10-31-2007, 10:32 AM
Default Re: Different gear ratios?
I tried to run a 19 pitch prop with that lower unit, but it made the motor run to tight
What does "too tight" mean?
Fr. Frank says:
Currently without a SeaCraft
Old 10-31-2007, 02:53 PM
76Red18 76Red18 is offline
Slow to plane, slow to reach wot under load, slow throttle responce.
J. M. Hendrix
Old 10-31-2007, 03:50 PM
So, with no other changes, the motor with a new lower unit went from not being able to turn a 19, to now being able to turn if just fine? Or was the old lower unit not able to turn the 19, and the new one does it just fine?
Fr. Frank says:
Old 10-31-2007, 04:55 PM
The 19 seemed like too much prop with the old unit. The new unit turns it alright. 3-4 seconds to plane(15 to 18mph), probably 8-10 seconds to full speed (42mph @5500)
J. M. Hendrix
Old 10-31-2007, 06:49 PM
I'm pretty sure all were the same
Old 10-31-2007, 07:41 PM
You've probably gotten a different gear ratio, all else being the same. The 99 Evinrude V6 Ficht and eTec motors were available with 1.85:1, 1.86:1, and 2.0:1 gear ratios. Most got the 1.85:1 ratio. A very few got the 2.0:1, and the 1.86:1 ratio were all foreign distribution.
A note of warning. The 1993 through 2002 oem gears for Evinrude and Johnson were very poor quality, and their single biggest issues were pinion gear failures. BRP fixed the problem, so if the gears are new, you're okay.
Fr. Frank says:
Old 10-31-2007, 08:09 PM
Thanks for the info & the warning. Probably got a lower gear, which is alright because the 19 Michigan Apollo deosn't lift the bow like the 17 Viper did . As for the gears, I think they were just inspected . I purchased the unit as "reconditioned".
J. M. Hendrix
