Old 11-03-2007, 10:26 PM
Tarpun Tarpun is offline
Default Re: Materials
i didn't know vinegar removes epoxy. That by itself is a reason to use it instead of polyester. Epoxy is stronger and bonds better.
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 11-04-2007, 12:57 PM
WillyC WillyC is offline
I didn't use plywood for the transom. I used one 4' x 8' sheet of coosa board that was 1 1/2 inch thick. I did use one sheet of plywood to recore all of my hatches. I think it was 7/16" non treated. For the transom you will need two sheets of 3/4 inch plywood - at least that is what a majority of people use. As for the floor, I dont know. You will have to take a couple of measurements to determine what you will need. -will
Old 11-04-2007, 03:15 PM
doug7488 doug7488 is offline
Only when it is still uncured.
Old 11-04-2007, 08:50 PM
will- Thanks again was looking at the coosa...Pretty expensive but I may spring for it!
Old 11-04-2007, 09:19 PM
i would probably do my transom with the coosa but wood for the floor because of the way it holds screws better for the top and console and things.
by the way mine is getting close. you still want to plan a trip?
Old 11-05-2007, 12:29 AM
yeah lets go...let me know
