Old 12-06-2007, 02:23 PM
3rdday 3rdday is offline
Default Re: Marine diesel
I appreciate your opinion. Thanks Good point on the 4 stroke OB. with the diesel at 10-15% better economy, it would take a long time for the Return On Investment. Although it could be a lifetime engine.
Old 12-06-2007, 02:36 PM
JohnB JohnB is offline
After thinking about some of the oil burners I have been on, a SeeVee in particular, I think at lower speeds, 25 mph or so, they might actually get quite a bit better fuel burn. The down side is weight. In a 23' boat, a diesel is probably about max weight on the boat. With all that weight, you have to push it harder to get more of it out of the water. I am not sure that 23' SeaCraft hull really performs it's best with that type of power. The inboards do ok, but it is a different kind of boat/ride. More like a ship, than a boat. They plow, rather than slice.
It's hard to explain, unless you drive one.
These new outboards are really starting to get some gas milage, but it takes a lot of gas to pay for a 15,000 motor.
From what I have seen, 25' of boat is the break point for going to twin outboards, or diesel. The advantage of the diesel is milage and low center of gravity. The advantage of the twins is speed and redundancy, while giving up balance and fuel milage. If there was a perfect solution, there would be only one kind of boat
JohnB / 23' SeaCraft
Old 12-06-2007, 04:10 PM
Very logical and well said. Thank you for the help and perspective !
Old 12-06-2007, 06:29 PM
76Red18 76Red18 is offline
I'm paying $3.48 for a gallon of diesel and $3.05 for unleaded down here in S.W. Fl.. Haven't done the math, but maybe diesels' not the economical choice anymore.
J. M. Hendrix
Old 12-06-2007, 08:17 PM
is that diesel off road diesel/ should be $ less... as it is taxed differently
Old 12-06-2007, 09:19 PM
No, its at the pump but theres nowhere around here to get it in small quantitys. If you have a site prep or land clearing operation you can get a large supply delivered to a large holding tank. I dont have that type of an operation so I just pay at the pump for my trucks that use diesel.
J. M. Hendrix
