Old 01-05-2008, 09:13 PM
riptide riptide is offline
Default Re: QUES ON INSTALLING NEW GAS TANK IN 23 SCEPTRE
I'm having a new fuel tank made also for my Spetre.Its going to be 3/16" alum and then coated with Coal tar epoxy.
You will never have to worry about corrosion again.
77 Sceptre 250 Suzuki
Old 01-05-2008, 09:45 PM
htillman htillman is offline
I have not thought about coating the tank but will look into it. I firmly believe in a well sealed hatch with no foam. I am putting a sight glass above the tank to be able to visually monitor it.
Old 01-05-2008, 10:08 PM
Coal tar epoxy is the only way to go.The guys at classic mako swear by it.Some guys use a primer first like awlgrip 545 and then the coal tar.
Old 01-06-2008, 12:05 AM
Where do you get it? How do you apply? Is it better than epoxy coating a fuel tank? As I understand it can be applied to aluminum.
Old 01-06-2008, 12:16 AM
sponge sponge is offline
Rhino Liner the stuff they use on truck beds works great.
Old 01-06-2008, 12:24 AM
JohnB JohnB is offline
I would use either coal tar epoxy or zinc chromate on the tanks.
JohnB / 23' SeaCraft
Old 01-06-2008, 01:36 AM
You can get coal tar epoxy here
http://www.grainger.com/Grainger/wwg...mId=1611684578
http://www.grainger.com/Grainger/wwg...mId=1611684576
