Thanks GSF,
How do I fix a hairline crack by a screwhole. It`s attached at both ends. Joey was that Bristol Finish on the Jenna Mae? Has anyone used Bristol Finish? GFS |
![]() Yes that's Bristle on the Jenna Mae,about 6 coats I think.I really like the stuff.You can recoat it in about an hour,you don't have to sand in between coats,it held up pretty well down here in the intense summer sun and after about 30days you can clear coat it if you want,but I didn't on the Jenna Mae.It's a two part varnish and goes on real nice with a sponge brush,I think it's about 60.00 a quart. You can make a filler for the crack by mixing teak saw dust and a clear drying glue(I use Elmers)and just fill the crack,let it set up and sand it smooth.You will be able to see it,but it won't jump out at you like the crack would. I just went and looked at the boat on my site and let me say that she has Bristle on the ToeRail,Transom,Helm Pod and Brow Cap.The covering boards and cockpit sole are teak and just oiled. |
Yeah, I was at their site and they have lots of tips and info.
Maybe that`s the way I`ll go. Did you use the honey or clear? Any thoughts all? Thanks for the crack Capt. GFS |
I use the clear. I would say again do it in the shade and keep the coats thin, it will run and get little bubbles if you try to put on too much .Always go from dry to wet and put on a bunch of coats,I'd say 10 and forget about clear coating with the AwlGrip.If you mix up more than you need for a coat and you plan to keep at it that day,put the unused in the fridge until your ready for the next coat.That will slow the kick time and extend your pot life,just warm it in the sun to get it easy to apply again.Don't worry about little runs and screw up's at first,build up a good base of varnish,then sand and fair out any mistakes before the final coat or two.
Jump on in there and get'er done,you will be very pleased with the result and very satisfied that you did it yourself! |
TODDS LURES RULES!!!!! Unobtanium obtained! I now have in my humble little hands a beautiful dash and glove box w trim. AND the plexi doors /frame w trim for the bottom of the console.
Thanks for the transport 65 Bowrider! The junk I had in there was a homemade ply affair that was being held up by 2 screws. One good wave and the whole thing would`ve come down w my gauges and radio.....Why do people do things like this? Glad I kept digging. Like Papa said , you`re never too old for a shovel. Well, I had almost finished sanding the splashwell , but now I think I`ll get going on the dash! I`ve been dry for 6 wks now and I`m worried about the fuel. 3/4 full , and run every other week to keep the carbs happy. If I can redo the dash and get the console down , I can slash her and burn the old gas up. Then I can continue. Can I add Stabil to the fuel now and take the trailer round the block or do I need to burn that gas up soon? Off to B.O.W. for beauty supplies! Thx Joey, Bushwacker, GSF, and all. GFS |
Bushwacker can you PM me your phone # please.
Thx, Gfs |
I bought some 1x3 4 square teak for my permanent pads for my leaning post From Jeff @ nautical specialties 1 mo. ago.
Thought , It`s not just for breakfast anymore! He was redoing a 26 Blackfin combi and his joiner work was 1st class. Luckily he was at the shop over by CrackerBoy. We discussed pros and cons. 1 part Epifanes it is. What pushed me over the fence? Never having to strip it ever again? Scuff, recoat , enjoy! Bushwacker, do you ever get tired of ALWAYS being correct? Wish I knew half of what you`ve forgotten! The Epifanes site has all the info this rookie will ever need. Take a peek. I highly recommend it. Just back from B.O.W. <60 clams for 1 qt. and thinner. Hi Ho Hi Ho...., GFS ![]() |
What I like about the Epifanes is it's a 1 part deal, just open the can and apply. Both Honey Teak and Bristol Finish require a catalyst, which means you may waste some if you don't mix up the right amount. When I used the Honey Teak, I just mixed small batches using syringes, and made more as required to minimize wastage.
