Old 03-27-2008, 04:59 PM
Default Re: Trim Tabs for Seafari?
Hi Dennis, Thanks. I compared measurements and door and frame they have definitely been replaced. I'm going to try to use the door as is even though its shorter and narrower. I guess I'll expand the frame width a bit or see if I can find an original or slightly over-sized one. Maybe the height difference allows for a portable/convertible 6-10 gal gas tank box. Either way I'll be making a new frame out of teak and attempting to salvage the original teak ply of the bulkhead. Hopefully I don't need to replace it because I really don't even want to remove it. And teak is pricey around here. Thanks for the insight on the tank, too. Thought it might have tapered ends but I hadn't actually determined that. I'll explore that after work...
-Gillie
