Here's an easy way to understand the difference: a submarine that's 500 ft underwater can cavitate when too much shaft speed is applied too quickly. But it must be at the surface to ventilate. A powerboat whose propellers are piercing the surface of the water is ventilating. Another note, Most new stainless props are designed to both cavitate AND ventilate. Their designed to cavitate at the sudden application of power at slow speeds to allow the propeller shaft rpms to rise rapidly, getting the engine quickly into it's power band. They are also designed to ventilate slightly at high speed, running right at the surface, to eliminate as much fluid drag (or friction) as possible. That's why the trailing edge of each blade is cupped. The cupping allows the blade to run at the surface, and the cupping holds water against the rear face of the blade, minimizing ventilation. End of lesson. ![]()
