Is there a reason that mounting a 30 motor higher is better, besides getting it out of the water more? Trey
Trey '64 13' AeroCraft, 15 Rude '74 23 SeaCraft, 225 Opti '84 18' Winner, 150 Merc The bitterness of poor quality lingers long after the sweetness of low cost. |
Thanks for all the info ....but i'm still a little confused about shaft length. 30" or 25" for transom mounted single 250hp?
Measure the transom and see what it needs.
The first true 30" shaft engine wasn't even offered until 1992 by Yamaha, long after the Potter era was gone. Prior to that, you could buy 5" extension kits, or order an engine extended by 5", but these kits were really for making 20in. "long shaft" engines into 25in. "extra-long shaft" engines. Nonetheless, Peter is right - measure the transom height, keel to transom lip.
I just had a Honda 225 hp w/30" leg installed on my 1989 SeaCraft 23WA and sits exactly where it should. Looks great and the boat handles the extra weight just fine. The transon came from the factory with the cut out for twins. I don't know if they (factory) did anything extra for that set up or not.
I have only put about 2 hours on it, seems to handle the boat great. Fishing opens back up here in the islands on the 1st of July, so it will get many more hours on it.
Gary |
I am a newbie so some of this discussion gets a little granular. I did 40 mph measured by a garmin GPS in my 23' CC from Chatham to Hyannis with a 2003 2-stroke Evinrude Ficht. All the power needed to get up fast and just go. One thing I don't see discussed much is the noise. My daughter is a competitive sailer and we use the boat to coach/watch events. Spend time around four-strokes and you yearn for the quiet when operating at slower speed. As to fuel costs, one needs to take into account how much use the boat will get in a year. Sometimes granular evaluation of MPG or GPH is moot.
OK not my thread, but I am mulling the same question (twins or big single...)
1. Cape cod. Falmouth, but also plan to hit chatham pretty regularly. 2. Mostly nice days for striper, blues, but preferably bonito, albies. possible offshore for rec tuna on super nice days. 3. Completely redoing/closing transom. Definitely a brackets. The two options I looked into, price is about the same: - single 25" suzi 250 on single bracket - twin 150 HDPI 25" on twin bracket Leaning towards single 250. |
If and/or when on my 23' I'll consider the Zuke 300 first.
check tramson befour putting on new motor raised mine from 25 to 30 sinch also seal up any holes in well cables ect.used mine with old 2 strokefor05 3years went to suk 25o double fuel millage quite no problems for 3 years 46 mph
