Andrew,
The Seastar hydraulic cylinder mounts on the "tiller arm" of the motor and the piston rod it rides on attaches to the tilt pin on the engine bracket, so it won't matter if you raise and lower motor with the jack plate, provided there's enough slack in the hydraulic lines to accommodate the motion. The mechanical push-pull cable steering thru the tilt pin might be harder to rig up and more exposed to corrosion.
Bushwacker
I should have specified..the jackplate is manual, so I won't be raising and lowering all the time. I'm worried that when I tilt the motor up all the way, the cylinder might hit the jackplate, therefore leaving part of the lower unit in the water. I also believe that the mechanical steering would be more difficult to install. |
I guess you'll have to get some measurements from motor like yours with the hyd. cylinder installed; clearance may depend on setback between jackplate and transom, and vertical setting of jackplate. I have about an inch of clearance between cyl. and mount pad on my f/g bracket with motor in full tilt position.
The Seastar Cylinder mounts through the tilt tube of your motor, and won't give you any clearance problems on a Jack Plate. A Jack Plate is basically an extension of your transom. Do you need a Seastar system? HH5269 1.4 Helm, HC5345 Cylinder, and (2) hoses fabbed to length you spec, $700. All new and full 3 year warranty.
Bob, just sent you a PM
Snookerd |
I'm sorry to hear about what happened...reverse threading it then drilling it out can be a pain in the butt. By any chance, do you have a picture of your bracket with the jack plates so I can get a much clearer idea of how it is mounted?. Mine is also a CMC. |
The bracket was the key. Also the pre-inspection of the steering system as described in the Teleflex manual. Interference possibilities do exist, and Teleflex clearly warns the operator about checking for the possibility of interference.
Always, ALWAYS, determine, slowly, the a ability of full travel, including hardover, when a Seastar system is installed. Only takes a couple of minutes, but saves a bunch, time and dollar wise. |
Snookerd |
