Old 06-30-2008, 02:43 PM
htillman htillman is offline
Default Battery Cables
I need a 8' long battery cable, can I bolt two 4' sections and heat shrink the connection?
Old 06-30-2008, 03:13 PM
Default Re: Battery Cables
Go to your local welding supply shop and buy 1/0
or 2/0 cable from them. Solder on the copper ends and use red heat shrink to identify the positive cable.
Splicing could cause a current lose.
See ya, Ken
Old 06-30-2008, 08:20 PM
Ken is right. You can even buy 2/0 at most Home Depot stores. It ain't cheap, however, at $9 to $10 per foot for single-conductor tinned aluminum cable. But it's definitely the way to go. AWG 2/0 two conductor cable from Pittsburg Wire is really good quality stuff.
Fr. Frank says:
Currently without a SeaCraft
Old 06-30-2008, 08:58 PM
Et23, Quit screwing around splicing battery cables. You and your Seacraft deserve better. Do yourself a favor and checkout
http://shop.genuinedealz.com/Marine%...ttery%20Cable/
You order what you'll need send them a separate e-mail with instructions anda couple of days later you'll have the best cables you've ever seen, and money left over for beer, err, gas. They are excellent. Top quality boat cable - tinned copper. Their prices are better than port supply wholesale and they'll cut, crimp your lugs, and heat shrink as few or many connections as you want for $.99 each end. They are fast and accurate. They're based in Brunswick GA. They got my stuff to San Diego CA in 3 day UPS ground. Honestly, I think it's one of the best groups I've ever dealt with. Check it out - I think you'll be pleased.
Old 06-30-2008, 09:40 PM
waytogo waytogo is offline
skycraft in Orlando has welding cable and I believe it is cheaper then most places
Old 06-30-2008, 11:45 PM
rhody98 rhody98 is offline
I ordered from them also, quality work, decent prices and they custom cut cables to order with whatever lugs you want.
Old 07-01-2008, 12:31 AM
Thanks for the options, I will check them out.
Old 07-01-2008, 01:19 AM
Skycraft
It has been my favorite little place for over 30 years..
I4 & Fairbanks Ave. In Winter Park, FL.
See ya, Ken
Old 07-01-2008, 04:24 AM
Wow, good stuff down there... great prices, too. Wish I had a shop like that nearby.
Old 07-01-2008, 10:18 PM
seabob4 seabob4 is offline
et23,
Unless your running a diesel or a thruster, 1/0 should do you. How does $85 sound for 8' of red and black? Pacer Marine, REAL marine cable. Darn close to Ancor cable. Let me know. Need lugs?
