Old 07-11-2008, 06:30 PM
Default Re: Windscreen replacement
i just made my own replacement windsheild. it came out almost perfect and only cost 80 dollars opposed to the 200 plus everyone wanted to make one
Old 07-12-2008, 12:26 AM
kennmazz kennmazz is offline
Thanks, just curious, did you use 1/4 inch plexi and how did you bend it?
"To know what is right and not do it is the true cowardice." -Confucious
Old 07-13-2008, 01:10 PM
yea i used 1/4 inch clear that i got from home depot. i bent it with a heat gun and it came out really well.
Old 07-13-2008, 07:06 PM
Thanks for the tip. I'll give a try.
Old 07-20-2008, 05:57 PM
Solafide Solafide is offline
I made a nice one out of 1/4 plexi but it broke when I was drilling out the mounting holes,I then made one out of 1/4 lexan and the material was much more forgiving and was easier to heat and bend.Leaxan is slightly more expensive but is well worth it
Old 07-21-2008, 01:27 AM
nos3665 nos3665 is offline
On heating and bending, Once curve or bend is made use wet towels to "set" less holding time.
plexi and lexan both use a special drill bit to help cracking or breaking.
Also once the holes are drilled use debur tool on holes.
Old 07-21-2008, 09:11 AM
datngrizz datngrizz is offline
I j ust got a quote of $145-175 from UPD Plastics (updplastics.com)for my 78 20' MA. They did not have the pattern in stock (they do have some SeaCraft patterns) so I will need to send in detailed measurements or my old screen. I will do the latter since I have my old one in pieces. I will let all know how they turn out.
OBTW, I just oriced Lexan and plexi...prices have almost dooubled due to oil prices. The price above beats what I canmake it for withe scrap etc.
