Old 08-14-2008, 10:32 PM
seabob4 seabob4 is offline
Default Re: Help Tank Removal
Once picked up a fully rigged Aquasport 250 Osprey from the rigid hardtop on top of the T-Top frame with only 3M double-sided foam tape providing the bond between the top and the rest of the boat. Twin 150 Fichts already hung and rigged. Incredible! That was in '98.
Old 08-15-2008, 10:26 AM
Ed Ed is offline
Default Re: Help Tank Removal - IMPORTANT!
DO NOT use any powertools while removing foam from a fuel tank. Use hand tools, such as a pruning saw or bow saw blade.
I know someone who spent 3 days in the hospital after fuel vapors in the foam flashed over as the result of an electric tool that was being used nearby.
Old 08-15-2008, 11:25 AM
Sage advice, but you have a long hose w/ the pressure washer in the driveway 20' away no?
Old 08-15-2008, 01:03 PM
Ed Ed is offline
I was not referring to the pressure washer, my comments were directed at the sawzall.
A pressure washer should be safe as long as the motor is outside of the boat.
Old 08-17-2008, 02:36 AM
dragin22s dragin22s is offline
was he inside with no ventalion, i just dont see that happpening outside or in well ventilated area or soaking the foam with water
Old 08-17-2008, 11:34 AM
76Red18 76Red18 is offline
Do you know how an electric motor works??
J. M. Hendrix
Old 08-17-2008, 03:10 PM
I see it happening. Vapors tend to stay LOW.
