Old 10-20-2008, 08:26 PM
Default Re: Replacing Fuel Line 1975 20' CC
Tex
You should have an inspection plate under the console. The fuel line should be accessible inside. Generally it's secured with two hose clamps but because of the age, you might have to cut the line off. I would secure the "New Fuel Hose" to the old at the engine. Then pull the "Old Fuel Hose" thru the inspection plate with the new line following thru in tow.(a little Vasoline on the line helps.) Hopefully the line is free and not jammed up or secured with tight hose clamps along the way, whereas you might have to remove the deck hatch
Good Luck
Old 10-21-2008, 12:35 PM
Texascoastalfish Texascoastalfish is offline
Thanks Cap'n.
By inspection plate you mean the rather large hatch secured by
many screws directly under the console ? I wasn't sure if it extended all the way in front of the CC where there appears to be another access point. Just wanting to be sure I take off the correct hatch. Thanks again !
Old 10-21-2008, 01:23 PM
You shouldn't have to remove the screws, it should unscrew. The screws usually hold the outside frame down.
Old 10-24-2008, 12:45 PM
I had my guy remove the access hatch. It entailed completely removing the Console to open the tank coffin. He said its the heaviest Console he ever saw ( I'll take that as "Well Built" !) Upon inspection the Filler hose was pinched between and unused mounting ear and the edge of the coffin. So Im replacing the 1/1/2" helical fill hose as well as the 5/16 fuel line. He was amazed at the great condition of the tank and mentioned his 21 foot Mako had a foamed in tank and water has eaten up the tank and it was a nightmare. My 90 Johnson is mounted and running great ( after tearing carbs down due to Hurricane IKE induced mud. The Motor did get submerged after all. But we have been running it full of Sea Foam and fogged the cylinders. All looks good there. I have a replacement binnacle control box coming today and hopefully by this weekend it will be done. Also removed ALL old wiring and am running 2 hot and 2 ground wires from Battery to a fuse panel for my accessories. I will post pics when it is done. I want to get in on the Fall flounder run now in full swing. Its only money right?
Old 11-03-2008, 06:37 PM
Default Replacing Fuel Line 20' CC- Lost Fuel Sender Wire
Hey All,
I have finished Phase I of my Project. That was to Re Power to replace blown motor, Replace fuel Fill and motor main fuel line from tank, Install Fuse Box, Water Separator, Replace broken Binnacle Control Box, Throttle and Shift cables, Red Plug wiring harness, Bilge Pump, and steering Helm unit and cable. All went well EXCEPT that after remounting Console I was pulling old brittle wires out of the conduit and I pulled the Fuel Sender wire back into conduit...ARGGG ! I tried to fish it but havent been able to get it yet. Heres my question
Without removing Console again and accessing sender under the deck hatch how can I possibly retrieve the wire, and if I cant, would cutting a round access panel in the hatch to get to the sender be wise/stupid ? I would need to know WHERE the sender is located and cut my hole over it. I REALLY want a fuel gauge. Thanks in Advance !!
Dave
PS: Fr Frank and Bushwacker. You were right. That 90 HP Johnson pushed me 34-35. Plenty hole shot for me.
Old 11-04-2008, 12:58 PM
Default Re: Replacing Fuel Line 20' CC- Lost Fuel Sender Wire
They really are not accurate. For Approx $125 go with a Northstar F210 Fuel Flow Monitor / Computer. It is easy to install and fits in the same mounting hole on the dash. You'll be glad you did
Here's a link to some shopping
Northstar Fuel Monitor
Old 11-04-2008, 04:58 PM
I, too, use the Northstar fuel meter but mine is integrated with my GPS and/or depthsounder.
Fraction of the cost of Flo-scan products...
Old 11-04-2008, 10:37 PM
gss036 gss036 is offline
That is a good link for locating prices and comparing all the stores and prices.
I just ordered one of the F210's from Rouge Wave Marine. They offered free shipping and w/o any sales tax the total price was only $115.95 delivered. I just happen to have an open 2" hole in my dash since repowering w/225 Honda. I have been trying to figure out fuel comsumption, now it will be easy. Only problem now is that we are shut down for salmon fishing until Feburary 2009 so I probably won't be going out until then, winter is starting to set in here in the Great Pacific Northwest.
Gary
Old 11-05-2008, 11:41 AM
Looks good, and thanks for responses. So the fuel computer would need to be told how much Fuel is initially in tank and then all the rest is automatic.
Old 11-05-2008, 08:12 PM
BigLew BigLew is offline
You will probably have to enter any new fuel amount as you purchase/add it.
Plan accordingly!
