Old 10-25-2008, 10:41 AM
Default Re: hyd. steering help
I believe the tube is pressed in to the motor section of the bracket, so you have to heat what it's pressed into. Heating the tube itself will only make it tighter! That tube also carries the weight of the motor, so supporting the weight of the motor to take the load off the tube should also make it easier to remove. . . also try to find some Kroil, it could make a difference!
