Old 11-03-2008, 05:31 PM
stoney stoney is offline
Default Re: dead batteries and float switches
This is my setup. The switch did have a piece of debris holding it open. I expect that could happen eventually and thats why I have two pumps, individually wired to a separate battery. I can live with aone dead battery but when one switch kills both batteries sometingwong!
I need better switches and to figure out why both batteris die.
http://i15.photobucket.com/albums/a3...bilgepumps.jpg
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 11-03-2008, 06:51 PM
Stoney, I dumped my rule-a-matic switches for their tendency to get crap stuck under them. The V angle between your hoses and the floats don't help either as they form a weir trapping even more debris.
The other rule-a-matic float switches like the Rule 40A would solve the debris jam problem. Rule also makes covers for the ones you're currently using. I believe the cover models are Rule 36 and Rule 38. They're probably $5-6 a piece. That's probably the way to go until the pumps crap out. Which might never happen in a bilge that clean.
Here's another switch that looks excellent by design.
http://www.sealandsanitation.com/sensaswitch.htm
As far as draining both batteries, I'm guessing that they are connected by using 1 battery switch that offers 1 or 2 or 1+2. If that's the case one battery drew power off of the other, draining both. Either separate the batteries by using 2 separate switches, or get the battery isolator I described earlier. It allows you to charge your batteries while under way, but it uses diodes and does not let the batteries to share current unless you move the switch to "Combine" which you only do for emergency starts. About a $100 online. $150 @west marine. Here's what it looks like:
Good luck! -- McGill
Old 11-05-2008, 04:45 PM
dcobbett dcobbett is offline
McCillicuddy,
What's the black box connected to the ARC with green wires?
Old 11-05-2008, 05:05 PM
It's just a 15 amp fuse directly grounding the ACR.
Old 11-03-2008, 06:57 PM
hermco hermco is offline
What is the battery setup? Battery switch type?
