Old 11-19-2008, 01:40 AM
Default Re: Outboard Brackets, Pro's & Con's
I'm pretty sure bayMFG makes a kit for the inline 6's.
The 2.0L v6's use the same baymfg kit as the 2.4L and 2.5L. Also for the 2.0L v6 you can also find the 5" spacer, 25" shift shaft, cut your own 1/2" copper tube, and swap in a 25" lower with the long studs(just make sure it's 2:1 ratio lower).
