Old 11-22-2008, 12:48 AM
Default Re: Scuppers and cap leaks on the Seafari
. . I found some .035" Moeller brass tubing but not sure if the thickness is enough, or what length. It looks like 1" O.D. x 4" will do the trick... Sound about right?
Gillie - the 35 mil thickness sounds about right. The tubes I got were already flared on one end, so I put them in from the top and flared the bottom; I think they were about 9 inches long . . I had to cut about 3" off of them before using. Just measure what you already have and figure you'll need to add at least 1/8" on each end to allow for the flare.
