Old 12-14-2008, 07:59 AM
ripndip ripndip is offline
Default Re: \"New\" 20 with a bracket
Zach,
That is one beautiful boat. Extremely well thought out. I am in the marine industry and pride myself on properly done, well thought out, appearance happy work, and your boat is perfect. Too often I see an otherwise beautiful boat where someone does something that makes you ask- what were they thinking when they did this? I did notice from the pics that you might be running some tab with them all the way up. I could see the constraint the bracket caused when mounting the tabs. I actually inadvertently did the same thing on my 1990 20' with 12x12 Bennetts, but a little more so than you. I never had any negative results from it. I wish I would have seen or been aware of this website when I redid mine in '99. I would have definitely copied several things you have done here- closed transom, bracket, raised floor. My old boat held 84 gallons (marine patrol must have put the tank in) and made at least a dozen solo island trips/never took fuel/200 Yamaha HPDI. I had weight/scupper/deck drain issues, but the ride and performance (3+ mpg) made it worth it.
I really like the dive tank idea, and the novelty of "my baitwell is strong enough to hold four dive tanks". The only down side I can see is swinging tanks around in such a beautiful boat. I'm not going diving on your boat. No sir, I'm not going to be the one to mark it up.
Congratulations and enjoy it.
Skyler
"Hooper drives the boat chief."
