has anyone with the in floor livewell removed it before? i think mine is leaking at the thru hull. i want to take it out and put a strainer down there and reseal the whole thing. i think it might be cabosiled to the floor and stringers? if thats the case that means its in there. it has been out before because around the perimeter of the well its got screws in it. ill post pics tomorrow when i see the boat.
Yeah I removed mine....Remember I made that through hull my pick up for the wash down pump.....
65 Bowrider has mine. Best thing I ever did. All systems for that become clear. Mine is an `89 so not sure that translates. Check post wide open for b4 pics.
GFS |
yea i remember you took it out. im just tryin to put a strainer down there and put the livewell back in.
I dont see a problem doing that....
How do you take it out? Have to cut it out? I thought the screws were just for the "lid" with the smaller opening in it, but never tried to give it a tug I guess. I want to remove mine and just leave the bilge access, as I will be using a leaning post style baitwell (and that would be a nice hand hole to plumb the dang thing, too).
well i think mine has been out before because i think the floor has been done at some point even though it has some bad spots. im gonna work on it tomorrow after work.
ok... its not coming out. its part of the inner liner.
I cut mine out w/ a sabre saw , and it was not attached w/ anything on the bottom .
GFS |
did you reinstall it?? im tryin to do that so i can fix the leak at the thru hull.
