Bits...,
I think I understand what you're saying. Release the steering rod (arm) by disconnecting the bolt. Center the steering wheel and cable end (steering ram) then center the drive to see what length the steering rod should be and adapt accordingly. Right idea? When I do that action, the steering arm is about 1/2" short as you suggest. Is there any adjustment of the connection nuts? Would releasing some grease via the zerk nuts allow the cable end (steering ram) to retract a little more? I only need a half inch...
Well I took my own best advice and lit a match to the Seafari and bought 1969 18' Glaspar Seafair Sportsman. A true left coast Classic.
![]() No, really, just updating my steering issue. bitsamonkey suggested that my steering link was too short. He had his augmented... what-ever ![]() ![]() But it made me wonder - why did it seem too short? To me it seemed the cable was not fully retracting into the tilt tube that houses it. Something had to be stopping it. Starting with the steering cable fully extended I removed the zerk on the steering cable here it goes into the tilt tube, and started cranking on the helm. From full starboard I turned the wheel hard to port. Each time I pulled to port a dab of grease would burp out the zerk hole at the end of the turning point. Each turn I would gain minimal travel. Did this for about a half hour to gain about half a turn of the steering wheel. And now have full turning to port and starboard. Turns out a bunch of grease and crud had accumulated at the wrong end of the cable end and was being compressed with no where to go each time I'd try to steer to port. I think who ever lubed it last had maybe have lubed it without fully retracting the cable end rod, creating an air or grease lock. Lesson is fully retract your steering before lubing. Says so right there in the manual, go figure... Anyway, problem solved ![]()
