Old 02-22-2009, 11:34 AM
Default Re: questions about recoring hatches
nat - use the squares. There is no advantage to using 1 piece of core. The strength comes from the skins, not the core (which is why you could even use balsa wood or nida core) As hermco said you risk trapping air under a large sheet. Squares also make a stiffer laminate.
