I'd go with what Rich said, if you want to go back to gelcoat, I'd get used to the paint. In addition, even if the paint was enamel, you could prime over in and put on a polyurethane based paint, provided the enamel has been on long enough, sounds like whatever is on there is pretty tough.
I think someone did this in one of the northeast boating magazine, he used soda blasting
Arioch ![]() |
Soda blasting is fine if you are doing the bottom, if you are doing the topsides it will leave voids and pit the entire gelcoat surface, at which point you will either have to regelcoat the hull or fill,prime and paint it again, which you already have, so unless the paint is peeling off there is no need to soda blast it, prime it and paint it, nothing wrong with a good poly paint job, for some of us it is better. it's a big boat mentality.
