Old 04-07-2009, 11:35 PM
wtenglish wtenglish is offline
Default Re: 1978 SF restoration, my first one.....
you are doing a really good job on the controlled chaos of tearing the boat down. As one of the other guys already said Stricks boat spread from not having a brace across it. I would make one so it was removable with two screws while you were working inside and then be able to reinstall after the days work is over. what are you plans for everthing? From the pics and how fast you are going it doesnt look like this is your first rodeo. Keep up the goods work and the pics coming.
BTK, that is a good idea and I may give it a try. Another method that I read on one post was to cut a dado in two ends of a 2x4 and just drop it down on the pre-measured locations. I definitely need to hold the original form and avoid any rework if possible. A lot of the design is still fluid right now but a couple of things I'm hoping to accomplish will be able to accomodate a 175hp to 200hp 4 stroke engine with a 16-20 gallon livewell in the stern. At this point I'm thinking about purchasing one of Hermco's brackets for twins and having it drilled for a single for the additional flotation. I've got some sanding to do and it will give me a chance to put more thought into the details. Nobody told me this stuff's addictive, I'm having a hard time focusing on the day job!
Will
