Old 03-31-2009, 05:38 PM
thunder thunder is offline
Default Re: New member iso 1st Sea Craft
Great talking to WWP2. look forward to seeing your 23.
And thanks to you Tucker for your input, yes if you have the info on those 2 I would like to have it.
<'{)()()< Fish Hard from dark to dark :30 ///
I want a 23' Sea Craft CC to try for a while as I am still looking for that "perfect boat"
Old 04-01-2009, 07:51 AM
If you check the Miami and Ft. Myers Craigs list you will see that there are 2 CC inboards for sale.
Old 04-02-2009, 10:44 AM
MasterBaiter MasterBaiter is offline
The boat in Florida is sold and can't find the info on the diesel - sorry.
One of the boats from Craig's list has a bad engine - if the hull is decent, repowering it is straight forward and not expensive.
Good hunting.
Old 04-02-2009, 03:31 PM
I saw a 25' in palm beach with a 454 straight drive, that sounds right on the spot for me. It's just too far away for me to get to at the moment. I perused the brochures mentioned above and did not see a 25' CC built in that time frame. I wondered if it was a sceptre conversion.
There is one in Newport, NC that looks real good, it's a "POTTER" 23' CC with twin 120hp rudes (1990 model engines I think) one running and one not with a standard notched transom and a nice trailer but at $10K it's a bit pricey with one bad motor and the other unknown. Both in bad need of paint. I plan to go see it though if still available the next time I go to MHC.
Old 04-09-2009, 11:02 AM
WHAT'S THE GENERAL CONSENSUS on the best power configuration and horsepower between outboard, I/O and inboard. Was a jackshaft ever available? I have seen the outboard 23' models range from twin 120hp on up to the big singles. The inboard 23' models range from small diesels to big block 454ci. And the I/O's from ?? to 350ci. The transom open or closed with a bracket.
Personaly I think the straight drive with big block or the closed transom with twin small to medium sized outboards would be my top choices. However I don't want to be under powered. So how much HP is required for a 23 footer in the single and/or twin outboard configuration. I know a 350ci to a 502ci would do well in a straight drive or I/O setup but is there enough room for the big blocks? I am looking for my first Seacraft so I want to shop in the right direction.
Old 04-09-2009, 11:37 AM
stumpie2 stumpie2 is offline
there was not a 25 ft cc that i know of that was a " potter built".... the 25 seafari's are sceptre's with bigger cabins.. pretty rare... the only 23 inboard that ive seen is craig miles' in va. beach (nice boat)... i have a 25 seafari if you would like to take a look at it... there is also a 23 cc with twin 165hp mercruisers in va. beach
http://i729.photobucket.com/albums/w...ictures007.jpg
I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!!
Old 04-09-2009, 12:42 PM
25' Seafari's are indeed very rare. But they are certainly not like a 23' Sceptre.
They are larger versions of the 20' Seafari, which was introduced in the 1960's. Check out the factory documentation elsewhere on this site.
Fr. Frank says:
Currently without a SeaCraft
Old 04-09-2009, 12:58 PM
The 25cc I reffered to (also mentioned in another post)is advertized as a 24'8" CC w/ 454 straight drive in south Fla.. And is assumed to be a 23 CC w/ bow pulpit added in the measurement???
Old 04-10-2009, 09:43 AM
Aw just buy a 25 Seafari, and make it into a center console.
Old 04-10-2009, 09:59 AM
seafari25 seafari25 is offline
Location: Eastern Canada...Wallace, Nova Scotia every chance I get
The actual LOA of my Seafari 25 is about 27'. The waterline length is just under 25'.
I measured a few years ago because the Marina that stores mine for the winter bills me for a 27' boat. He charges per foot.
