What's your prop? Are you running the original TRS drive?
Yes it is the TRS drive. So far I’ve tried a Lazer II, Ballistic, Mirage, and Revolution 4. The Mirage is the fastest however overall I believe that I like the Rev 4 the best so far. I want to try a semi-cleaver and a Bravo prop.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
Everything you mentioned but the Rev 4 is a bow lifter, I'd hold out for Fr Franks opinion, but I think you skip over the the Bravo series and the semi-cleaver and jump into the cleaver category. Get the rear end up in the air, keep the pointy end down, "bend the throttle and let 'er eat" as has been oft repeated here. I have never run that fast so this is just theoretical not my experience...Heck I don't even like to drive that fast
I feel that a cleaver might suffer at cruise due to not having enough blade surface area, however I'll try anything. At cruise I'm running 3500 RPM, 40 MPH and getting 2.4 MPG so I don't want my cruise to suffer just to get more MPH.
![]() Quote:
Here is a cleaver. ![]() Here is a semi-cleaver: ![]() and here is an almost-semi-cleaver from PowerTech, the OFX3: ![]() I truly don't know which will give you the best cruise performance, but I lean toward the almost semi-cleaver/semi-cleaver (or thru-hub cleaver). This may cost you a little top-end performance, but will cruise at 75% power better than a full cleaver. 75% power is defined in terms of hp produced, not in percentage of max rpms. For example, for my 90 Optimax, 75% power is 4600 rpms, which is actually 82% of max 5600 rpms. For my old t/260hp 26' Nova II, 75% power was 4400 rpms, 91% of the max 4800. It's important to remember that any cleaver-type propeller blade is at its most efficient when it is run as a surface-piercing propeller. The amount of blade surfaced for best performance is a matter of constant trial and error. Cleavers also ALWAYS cost you out of the hole performance, because of the cavitation induced under acceleration. For the record, I ran thru-hub "semi-cleaver" props on my 26' Nova II (and both RH drives) after trying a lot of props. That was partly because I ran offshore a lot, and cleaver blades don't shock the drive-train as hard on re-entry after launching off the top of a swell.
Thanks for clearing that up Fr. Frank, I figured if I spouted off I'd learn something yet again...Didn't think economy at cruise was an issue to a dude set on running over 60mph
![]() Quote:
I didn't do the hull work, but I did tune the rig on a 20' SF with a 240 hp. Merc Bridgeport on a hydraulic jackplate. We ended up running a custom prop from 2nd Effort in Lk. Hamilton, FL. The boat was REALLY, REALLY Squirrelly from about 55 to 62-63, and then settled down until reaching 68, which was WOT. Without trim tabs and the hull mod, there is no way it could have been pushed past 62. The hull mod was done by Rybovich/Spencer in WPB, and included a flat planing pad on the rearmost 5'-6' of the center V, much like the early Steve Stepp 22' Velocity hulls. With a similar modification, I believe a 20' or 23' can easily be pushed past 70 mph with modern outboards. I think your hull, Steve, can be pushed to near 80 mph with a similar mod, and a change in drive and engine, ..say to Mercruiser EU662-SCI. ![]()
I just cannot imagine running a small boat that fast. You sure could not do that in our waters here, there is just way too junk in the waters. Right now, it would be dodging the tribal crab pots and kelp. Me, I am just a simple boaters who likes to cruise at 25-27 MPH.
Gary |
I can still hear that thing coming in from about 3 miles in the ICW at Longpoint = The Sweet sound of Horsepower
Those speeds are not that ridiculous.
You may recall that the early '79 to '84 Thunderbird Formula 233SE (later called the 233LS) was available for order with twin 350ci/260 hp engines and (in '83-84) "Scimitar" gearcase sterndrives right from the factory, and could reach 74 mph "out of the box" in this config. (Post 1984 this was only available on the 242LS, 242SI or 272LS) The same hull was also available with a single 454ci. 330, 370, or 440 hp big-block Mercruiser and TRS drive. Standard power, however, was a single 198 hp Mercruiser or twin 170hp 4 cyl. Mercruisers
Display Modes | |
