Old 04-18-2009, 02:38 PM
Default Re: trim problems
There might be two solonoids, there is also some relays,locate the solonoids, then take a voltage meter or 12v test light, find which side of the solonoid has power to it, this would be the larger of the wires and post on the solonoid,then have someone activate the trim, check for voltage on the other large post or wire, if you have good voltage chances are it's the motor, you can also bypass the solonoids and relays and check the motor directly, that is another story.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 04-18-2009, 04:03 PM
jwclbi jwclbi is offline
Well as luck would have it after testing the solenoid, relays, motor, (and some beers) all were working properly. A wire, (rather difficult to reach of coarse) had coroded and was not making contact. Which is better than removing the trim motor again, as i didnt really enjoy that!! Thanks for the input Cayman, by the way your boat came out very very nice!!
Old 04-18-2009, 11:57 PM
I'd imagine the beers helped!!!!!!
Thank you.
1974 40' Eagle
www.parkeryacht.com
