Old 04-18-2009, 07:52 PM
bigeasy1 bigeasy1 is offline
Default Re: My Tsunami is finally finished(just about)
Thanks for all the kind words guys.
KENB,
the engine is a 350.I put new exhaust manifolds and risers on it along with a new water pump,plugs, wires,hoses etc.
It really didn't need all that,but i figured while it was out it was a good time to do it.
I also put a new intake along with a Edelbrock 600 cfm 4bbl marine carb on it.
It had a two barrel on it,as the guy blew up the previous block.He ordered the new engine,and threw all his old stuff on it.
I wanted a bit more power,and it was really under carbed(the previous eng was a 305.
Captainkass,
All my fishing is Great Lakes salmon trolling.I keep the boat at Olcott on lake Ontario.(about 15 miles from the mouth of the Niagara river.
It's mostly downrigger and wire diver fishing.
I'll post a picture of one of the salmon at the end of this post
Strick,
If you mean the frames,we bent them out of Aluminum tubing.I used alum.handrail fittings to attach them to the floor and sides.
I was going to use pedestal mounted seats,but we need all the room we can get for tackle boxes and other bulky stuff.
These frames let us slide a lot of stuff under them.
The seats themselves,are Tempress seats,(the $100.00 dollar ones)They really aren't the right seats for this boat,but money was getting tight,so they'll do for a while.They're actually very comfy,but they look a little weird mounted this way.
Captainkass,here's a pic of a few salmon we catch on the Great Lakes.
All this,just for a boat ride
Old 04-18-2009, 10:17 PM
Excellent job. Great looking arch, enclosure, and hull color. Those salmon look tastee! What a great set-up with the yami kicker
Old 04-18-2009, 11:29 PM
fdheld34 fdheld34 is offline
Awesome work...!!!
-FRED
Old 04-19-2009, 12:00 AM
I really like those 10 cup holders.... (I mean beer holders)
Real NICE JOB !!!
See ya, Ken
Old 04-19-2009, 05:15 AM
abl1111 abl1111 is offline
WOW ! Been there, done that ! Each picture brought me back to my resto. I was itchy just thinking of the work you did.
The end result is fantastic. You made yourself a custom boat. Enjoy the h*ll out of it.
I was wondering, how did you mount the tubular seat frame to the the inner liner ? Is it bolted through the hull ?
Old 04-19-2009, 09:35 AM
Thanks Al.
Yeah,you're right,I never want to see a Tyvek suit again.
The seat frames are mounted to the floor with ss screws into the deck,along with 5200 sealant.
The mounts to the sides were a bit difficult,especially the ones that are in the upper part of the liner.
The space between the liner and hull at that spot is only about 1/2".
We ended up using this tool that is kind of like a pop rivet gun,only it installs threaded inserts,that are only about 1/2" long.
A friend of mine is a mechanic at a chemical co,and he was able to borrow it.
We marked where we needed the holes and installed the inserts,and used 5/16"x3/4" stainless machine bolts to mount the flange.
They were just long enough to hold,but short enough to not touch the hull.
The rear tube is mounted to the pillar,so we could thru bolt those.
Old 04-24-2009, 11:20 PM
Thx for the clarification. She looks great ! I hope she treats you great - you deserve it. Happy fishing !
Old 04-19-2009, 09:48 PM
Captainkass Captainkass is offline
thanks for the pics of your fish there great
Kevin
Old 04-20-2009, 01:08 PM
KenB KenB is offline
Thanks for reply on motor... any thoughts on gelcoat versus one part epoxy primer for under decks?
Old 04-20-2009, 02:06 PM
I used Gelcoat because I'm familiar with it.I thought about going over it with the epoxy paint,after seeing it done by a couple of guys on this site,but seeing as it was waxed Gel-coat,I wasn't about to sand the whole bilge.
I do however,like the epoxy paint idea,not really sure which is better.
