Old 08-26-2009, 12:43 AM
jfm jfm is offline
Default Re: Fuel filler hose replacement
Next, I have to do the vent hose.
I have to do the same mod. I'm curious how you do the vent hose.
Any recommendation out there?
The only way to pass that vent hose is by cutting a small (4") inspection port at the top inside left of the strut/conduit that runs from the deck to the gunwale where both the fuel filler hose and vent hose pass through. There is no way to pass the vent hose through the small right angle hole at the top of the conduit with the new hose connected. That hole is just about the same diameter as the vent hose. It then takes a sharp right angle and connects underneath the gunwale out the side to the vent port. I'll let you know how I make out.
