Old 10-06-2009, 10:21 PM
Default Re: Merc XR2 thoughts opinions?
I ran an '91 2.0 liter XR2 behind my Seafari for 5 years. The caveat is that my XR2 was remanufactured, ported and balanced and produced over 190 hp on the hydro-dyno. I got rid of the original small bullet gearcase, and ran one off a 225 Merc with a 1.65 gear ratio, nose cone and low-water pickup. No jack plate, just mounted with the cavitation plate about 2 1/2 inches above the keel, with a hydro-shield on the skeg. Max rpm was 6150 turning a PowerTech custom designed and made 15.25"x16.5" 3-blade prop.
My best fuel economy with that motor was a trip up the bayside in the Intracoastal Waterway from Garrison Bight in Key West to Vaca Cut in east Marathon, about 58 miles overall, where I ran about 4200 rpms (34-35 mph) the whole way and got about 3.7 mpg.
The value of the motor is dependent on whether it's a salt or fresh water motor, how clean it is, whether it has maintenance records, etcetera. Ball park here would be $1200-1500 for a really clean one. There's an '89 XR for sale right next door to me for $800, but it needs refreshing as it was a commercial fisherman's motor and compression is only 110-120 lbs on all six
Fr. Frank says:
Currently without a SeaCraft
Old 10-07-2009, 12:12 AM
Thanks guys.
Fr Frank., 3.7 mpg is impressive, and I'm going to guess you built it for speed rather than economy.
Haven't seen too many XR2 around here at least not for sale. Is the 150 black max the same motor?
What should the compression range be?
Also is there a difference between the blue decals and the red? I had once heard that one was aimed at salt water and the other fresh water not sure which is which can you shed any light on that and if there is any mechanical or material difference?
ESD, Are you running the 200 on the MA? Are you pushing close to 60 mph on that?
Take it easy...
Old 10-07-2009, 02:37 AM
...I'm going to guess you built it for speed rather than economy.
It was actually nearly completed in being remanufactured when I got it. The best I ever got out of it was 6150 rpms at 46 knots on the GPS. (53 mph) At that speed/rpm and trim I was throwing up a 15' high rooster tail. Behind a Seafari, no less. Kind of funny if you think about it.
I bartered my work creating Mercury dealer's wireless computer network in return for the motor, for which they had been asking $5K. Previous to that, I had a Chrysler 120 on the back. No kidding.
...Is the 150 black max the same motor?
I don't think so. The Mariner Magnum of the same year is the same motor as the XR2/XR4/XR6/XRi. I think Black Max is just a marketing designation for all V6 Mercury outboards from the late 70's onward.
My book calls for 125 to 140 lbs for the XR2 2.0L models. You also want all six cylinders to be within 10 lbs.
I honestly don't know.
Fr. Frank says:
Old 10-08-2009, 12:59 AM
Thanks again Fr Frank. Another question,
I was looking on Screamansfly for price comparisons and the things that stuck out about these motors was a.) their "bullet-proof" make up and b.) that they really generate their power in the upper end of their rpm band. Although I suppose this holds true for most 2-strokes.
Does the latter imply that they xr2s don't run well at lower speeds, or can they run effectively @ 3500 rpm and less? At idle or trolling?
Truth is with our big broad swells rarely would I have the opportunity or desire to run 35-45 mph offshore.
