Old 10-30-2009, 01:50 AM
jeff6645 jeff6645 is offline
Default Re: Yamaha Carb(s) Rebuild??
I agree not that hard to do yourself. I just finished cleaning my Yamaha 250 yesterday; motor wouldn't run more than 1400 RPM, now runs great. I just clean them and replaced. Cost $35.00 and my time.
Some additional tips:
Count the number of turns it takes to screw in the adjustment screw (a soft set - not tight - just till you feel it touch) write this info down and set to same setting when complete. On my motor 3 one side were all set to 1 1/4 turns and the 3 on the other side were all set to 1 turn back from soft set, I think factory for mine is 1 1/4 yours may be different.
Don't disassemble the linkage, just snap off and set aside.
Make sure to get same cab back in the same location.
Check the gas lines for breaks or other defects and replace as needed. Have plenty of zip ties on hand.
Good clean fuel is also a must.
Hope this helps...
Jeff Pettit
Pettit & Pettit Enterprises
Mobile, Al.
1974 23' Yamaha 250 OB
Love My Classic Seacraft
Old 10-30-2009, 09:21 AM
Well, I took the easy, although expensive way out. I took it to the Yamaha dealer and had them do it. Cost $465 to have them rebuild them. I pick it up today. If it doesn't run right, it goes back to them for adjustment, on their dime. I felt I could have done it, but business/time commitments and lack of experience and ability to adjust/tune the carbs after rebuilding led me to getting the dealer to do the work. I felt the price was fair too.
