Old 11-09-2009, 07:30 PM
Trey1096 Trey1096 is offline
Default Re: T top help on 23cc
You could drill an oversized hole, like 1/2" diameter. Then wax a 1/4" bolt, put a nut on it, and epoxy it into the hole. After the epoxy sets up, unscrew the bolt and you’ve got threaded epoxy and an embedded nut that you can run a machine screw into.
You may want to gouge out some of the coring so the thickened epoxy would have a wider section between the skins to help prevent pull out.
Does Daltonmarineinc mean like Dalton Marine between Acworth & Woodstock?
Trey
Trey
'64 13' AeroCraft, 15 Rude
'74 23 SeaCraft, 225 Opti
'84 18' Winner, 150 Merc
The bitterness of poor quality lingers long after the sweetness of low cost.
