I did look at that and its ok
Hi Jorge
Jorge I can fish till my hair falls out and my eyes bleed and my hands cramp and then some.. But if I have to fix something cosmetically Im SCREWED... But that fasco product sands so smooth It makes a college ebucateded fool llike miself feel like a pro... I used the two part epoxy fairing compound about fifty a shot and hold up well below waterline. Sanded easy and turned out nice.. It looks so nice you tend to want to oversand thinking it can get better but only gets worse.. Best wishes and happy new year Chris ![]() |
I HATE SANDING!!!!!!
I'm about 1/2 way done doing to bottom but in some places the strip away product left some areas with bottom paint. I've tried sanding it but with the dust of the bottom paint(which I'm sure it not good for you) I have a mask..... I think I will wait till tommorow and buy some more strip away and let it work. But overall I am pleased with the results so far |
Sounds like you have time to post some pics
Here are a couple of pics showing the progress
Just as I wrapped it up and picked up the weather changed here..rain and a front coming in http://i22.photobucket.com/albums/b3...s/IMG_0003.jpg http://i22.photobucket.com/albums/b3...s/IMG_0002.jpg http://i22.photobucket.com/albums/b3...s/IMG_0004.jpg |
![]() Quote:
It's looking good on the prep work. This time of year down your way seems great for the Roll and Tip. She's gonna be one pretty MA.
Btw, Ya gonna fill those vents in?..Just curious
Thank goodness that in the scheme of things you are broke, powerlesss and inconsequential, because with the shortsighted alternatives and idealogy you have you'd be much worse than those you complain about. |
My idea is to have the vents but not in a way that water can get in.
The ones that came with the boat are in poor shape so I plan to get new ones. But now that you mention it filling in the holes might be agood idae. You guys just keep adding to the list ![]() |
Those vents are there for a reason (bilge ventilation), so I wouldn't remove them. I believe it's a USCG requirement to ventilate the bilge unless the gas tank is foamed in, because SeaCraft has always had bilge vents and non-foamed tanks, at least in the Moesly and early Potter days. Don't know about the later models - they may have gone to the foamed-in guaranteed-to-corrode tanks with no vents style of many modern boats!
BTW - I wouldn't crawl under that boat with the way those cinder blocks are oriented! At least turn them vertical so all the load is in compression. The way you have them sitting, you're trying to BEND the top surface, and concrete has virtually NO strength in bending! Cinder blocks are much weaker than most folks think. If you have any more of the solid concrete blocks or wood blocks, it would be much safer to use them! At least wood deforms before it fails; concrete is brittle and fails without warning!
Display Modes | |
