that thing would scream
With an HPDI,You would have to move alot of stuff forward in order for it to self bail, even with no one in it.
I would think you can find the weight of the current motor and the Yammi Then stack that difference in weight on the cowling or whatever. It should give ya an idea at the dock. Assuming there is a current motor.
Thank goodness that in the scheme of things you are broke, powerlesss and inconsequential, because with the shortsighted alternatives and idealogy you have you'd be much worse than those you complain about. |
There's no power on the boat right now, so I have nothing to compare it to and the floor drains still go through the deck; recently replaced with bronze. I'm affraid to pick the hpdi and then find out she's sits too low.
Seafari, where is the 200, on LI? Wish the hpdi's wern't so much heavier than the carb'ed ones.
26 Regulator Express 74' 20SF |
My setup has mine at the top of the bronze at rest. I really don't have any of the problems with weight and drainage and height that so many speak of. My motors only 410ish lbs. But 30" back. She would dolphin a little under 3200 in some conditions especially light on fuel, but the motor was not at the right height and there are no tabs. I love the simplicity of this boat! So I put an original cheap Stingray fin on and changed the motor height and gained 2 knts up top and I can't tell you how quick she pops you up on plane and now I can't make it porpoise. I'd like to get a blown 25" 175 60deg. Johnson/Evinrude to redo, super light reliable motor or an older non o-ring Merc. but really I want the OMC.
Display Modes | |
