The extra weight of the 150 will not allow the boat to self bail. You WILL stand in water with that setup.
I have a 150 Evinrude on my 20SF. I cross the drainage lines & it keeps much of the water out.
My 225 efi Merc weighs in at 475 lbs and my 20 sf still self bails.
I had a 20 Sceptre with a carbed 200 Yamaha on a jack plate and it would self bail fine also.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
I have a 20 with a 150 ox66 (precursor to the HPDI) and it self bails.
With that being said, it self bails for a couple of reasons: 1. Transom raised to 25" 2. Scuppers re-routed to go out the transom 3. 75gal fuel tank moved farther forward under the deck to balance the boat out (PRIMARY REASON)
2001 23 Regulator 2006 F250 Yamaha |
My 20' Seafari had a Merc XR4 150, at 370lbs, and would self-bail with no one on the boat. Step on board, and water came up on the deck. Currently has a Merc Opti 90 hp at 375 lbs, ditto. I have drain plugs in the deck drains which I remove once underway, and replace before coming to rest. Unless I'm alone, in which case my shoes just get wet.
![]() At rest, drains open, with me standing in front of the motor well, I have about 1/2" to 3/4" of water on the deck. FTR, when I had twin V6 150 Johnson motors on the marina's '77 23' CC in 1983, it sat with about 3-4" of water on the deck.
My 20 has a 150 yamaha fourstroke on it and it still self bails
tyler 1988 20cc |
