I know a 20' MA is not a flats boat or designed to get real 'skinny', but what are your experiences with how shallow they will run?
Working on my first project! ![]() 1979 20' Master Angler Suzuki DT140 |
I do a lot of plugging for stripers in shallow water and can run easily in 3 feet. If I want to go shallower then I tilt the outboard up deploy the trolling motor and can get into 2 feet without a problem....1.5 feet makes me nervous but I have been in it before.
Mine with a 200 merc will idle trimmed in 18", I do that alot down here, I was amazed - I usually look for 3' to get on plane
I have a Porta-bracket on my 20SF with my 150 ETEC on it - I can idle over about 12 inches of water - kicking mud, but not digging. It's about the only thing I like about the Porta-bracket.
If you have to ask, .....you need a flats boat.
I can idle through 2' with the 25. With the drive all the way up, the prop is still below the waterline.
She's in about 4' of water in this pic [image] ![]() Had to go through 2' of water to get in to this bay. Woke up next morning in 3' which made the narrows 1'. Had to wait for the wind to pick up to get out. Good thing it did but I would've stayed there for a few more days if it didn't ![]() |
Young guy, must be smart to buy a Seacraft trying to learn the "ropes" about boating. Seems like a good question to me.
Running on plane when I had the old Merc V6 on the back, near WOT and about 50 mph, trimmed all the way up to the point of ventilation, I have run through known 16 inches of salt water in the Salt River with my 20' Seafari. Likewise, trying the same stunt half an hour later, when the river was lower by 2-3 inches saw me chip my skeg on that very same rock shelf.
At rest or idle, my hull currently draws a measured 14" in fresh water and 13" in salt water. So I figure I need 18" minimum depth. (Remember that idling with the motor trimmed up produces downward thrust at the transom at the same time it produces forward thrust to the boat)
![]() Quote:
Thank goodness that in the scheme of things you are broke, powerlesss and inconsequential, because with the shortsighted alternatives and idealogy you have you'd be much worse than those you complain about. |
Display Modes | |
