Old 02-08-2010, 07:17 PM
MasterBaiter MasterBaiter is offline
Default Re: propane and paint
Depending on the heater - propane can burn very clean up to 99% Unfortunatly, you cannot get away from water vapor from the combustion. You can always run a de-humidifier at the same time, but unless you are painting with water based paint you won't have a roof or walls to hold the heat in.
