Withdrawal is real! Check out the last few pages of "Here we go again"! Strick, What was the 'Harbor Freight" tool you referred to? Also, any thoughts about fabricating an oval shaped liner and glassing it into the inner top of the seatbox? My '85 has the seat boxes, but the liner is not glassed into the inner top so I will have to seal them if I want to use one as a bait tank. I should also mention that each of the boxes have a small sump in the bottom with an outlet leading to an overboard thru hull. A perfect solution for either draining the bait tank and rigging up an overflow drain.
