Well I'm done for now. It could really use one or two more coats to make it lay perfect, but thats the beauty of varnish, just scuff it down with a white scotchbrite, then alcohol in 6 months and add an extra coat or two. All said and done I put 8 coats on, sanded with 220 and wiped with alcohol in between every coat. Then on the 8th coat I sanded half of it back off to level everything out more and did 3 more final coats that were sanded and wiped .
