Old 05-03-2010, 03:54 PM
CaptMick CaptMick is offline
Default Re: Over thinking fuel tank replacement
BigLew,
I have read that several times. It is a great link and makes sense for the application. (Bottom of hull belly tank) I got to thinking that based on what he is saying there I should drill holes in the compartment my tank sits in. It is a 60 x 24 x 8 gelcoated rectangular tub. that way air could flow. He says airflow is key to reduce the crevice corrosion. I do not see that following his plan there will be the best solution since the two locations and environments for the tanks, his and mine, are so different.
Maybe that is where I am over thinking it.
Great link and thanks for the post.
Mick
Old 05-03-2010, 10:23 PM
BigLew BigLew is offline
Mick,
You might want to consider using a 2" hole saw and put a couple of vent holes on the bulkheads fore an aft of the fuel tank enclosure in the hull. Also, be sure to properly install a drain to the bilge for any standing water that should accumulate around the tank. I think if you do this, David Pascoe's comments become very relevant. You have accounted for venting the tank space as well as providing drainage of any standing water.
Good luck. Just my 2¢ worth.
-BL
Plan accordingly!
Old 05-03-2010, 10:45 PM
I would say that BigLew is right on...My tank installer did the same...no foam, keep the air flow, watch what material you rest the tank on, and provide a drain for water collection. I researched Regulator 26's and found that the 90's versions had completely enclosed tank compartments...not good.
