Old 05-22-2010, 09:23 PM
nate22 nate22 is offline
Default Re: Bracket help
Ok,
Just an update for a future reference for others.
According to Armstrong a twin engine bracket must be mounted 23in up from the bottom of the transom, to work with a 25in shaft motor.
Because of this mounted hight the bracket sits to low, and comes below the transom of the boat. So it cannot work.
I guess I will be keeping my transom open.
Thank for the help everyone.
Old 05-22-2010, 11:43 PM
lost2a6 lost2a6 is offline
On my Sceptre, my bracket mounted about 2" below the cut out opening and worked great. I left the opening open and that made it really easy to get from the boat to the beach. Why are you saying that yours won't work below the opening?
Steve B
Old 05-23-2010, 12:25 AM
It would not work because my motor has a 25in shaft leanth.
If I had a 30in shaft motor I can mount the bracket 5in higher, and clear the bottom of the transom. The Armstrong bracket is 3 1/2ft wide at its mounting point in the front.
If I mount the bracket 23in from the bottom of the transom, the lower sides of the bracket flotation part will protrude out the sides of my transom, which will cause drag.
Old 05-23-2010, 03:05 PM
What motor do you have? I'm going to guess that Bay Manufacturing in Ohio has a 5" shaft extension kit for you... check them out.
http://www.baymfg.com/
Old 05-24-2010, 11:34 AM
Thanks for the info, I will look into that.
