Old 06-08-2010, 08:45 PM
Default Re: Fuel tank compartment
I washed it some as it had crud all over it and the water went down around the foam somewhere. This is a newer tank and the foam is probably fine, they may have put some in when the tank went in but hard to figure how to check it. I'll maybe slide an 1/8 tube down there to check, good idea.
Old 06-09-2010, 09:00 AM
Tashmoo2 Tashmoo2 is offline
My 1985 18 ft has a 1" hole in each aft corner of the tank coffin. My tank was enclosed in foam inside the coffin
Old 06-09-2010, 09:23 AM
Callipygian Callipygian is offline
Were the original tanks foamed in over the top as well?
Old 06-10-2010, 12:21 AM
CaptMick CaptMick is offline
My foam was on the sides only. It was also foamed around the fill hose from 4 inches below the cap to the front of the forward wall of the compartment. What a pain to get the hose out. But the tank itself was very easy.
Old 06-10-2010, 10:06 AM
What is the best way to determine if you have an original tank from the 70's?
Old 06-11-2010, 01:00 PM
they all have a sticker on top somewhere under the crud LOL - size - date of manu
Old 06-13-2010, 02:17 PM
adamcannon adamcannon is offline
My coffin box didnt have any drain in it at all when I took it out. I am going to drill a bunch of holes in the botom of mine before it goes back in the boat. I also put a layer of glass on my tank to create a bonded barrier between the foam and aluminum. I hope this will prolong the life of my tank.
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
