Old 06-13-2010, 10:36 AM
Default Re: '77 Sceptre Rebuild update 4-21-10
1) I wouldn't wait for things to cure between steps. It will eliminate the need to sand, and the bond will be much stronger.
I will agree with you on this...with the exception of the first penetrating coat of epoxy.
If you prime the board first and let it dry you then know how much the wood sucked in the epoxy.
If you don't prime the board the cloth will suck the epoxy away from the wood and the bond will not be as firm.
Hope this is clear.
