Old 07-05-2010, 09:39 AM
adamcannon adamcannon is offline
Default Re: I/O vs. OB
I like that an outboard has its own little compact compartment(no engine box in the floor). Probably the best thing about an outboard(and most of you have been here). You go out in the boat(I/O or OB) and the son-of-a-b@#$h breaks down and leaves you strainded. While the towboatus guy is dragging you back to the ramp you can have the OB unbolted(no cherry picker required) and making a nice little artificial reef that you can go back and fish later. With an I/O it is pretty easy to blow you and your boat into a million pieces if you were to forget to turn on the blower. The only thing I like about the I/O is the ride. They do ride much better in a chop.
1975 Seacraft 18SF w/2004 150hp Johnson 2-stroke on a 26" bracket
Old 07-05-2010, 11:43 AM
BigLew BigLew is offline
????- What's that about, or am I missing something?
Plan accordingly!
Old 07-05-2010, 05:32 PM
I was just saying if you had to replace an engine an outboard is easy to remove and replace. I was just joking about dropping the outboard overboard although I do know someone that got so fed up with an outboard that kept leaving him stranded that he did unbolt it and drop it overboard. Gas inboards have always scared me a little because there have been two or three that have exploded when the people went to start them around here where I live. Those gas fumes can be pretty dangerous when they are bottled up in an engine box.
Old 07-05-2010, 05:48 PM
Most seem to feel an i/o or inboard rides better in rougher water. I've never seen this occur with 20', 23' boats. In my expierence that applys only with slightly rough water and/or at a crawl. Also any advantage the i/o may have the outboard could compete with with proper trimability at speed. When you get above a certain point in wave/chop height or speed of the boat you want the bow to have the tendency to stay in the air. Again I am speaking of the smaller boats like here, once you get a little more length on the hull then it seems to be more of a tossup. I have rarely been on a quality smaller boat that runs better with an i/o or inboard in comparison to an outboard at what most would consider a practical speed. Now if we are talking about drifting or feeling like a heavier boat then I could never argue about an i/o. Most of the guys I know prefer outboards on smaller boats even taking into account some people love closed transoms and some hate brackets. Then again I may be nuts which has happened before.
I will say the nicest running small inboard boat I have been on is a 25 Rampone with a single cummins, amazing but makes a seacraft seem drier than Arizona. It would cut the tops right off of solid close 4's on the nose and put it all over cockpit at 20knts.
Just my .02.
Old 07-05-2010, 09:11 PM
Tiny Tiny is offline
had a 74 scepter 20 with a 130 yamaha (91) outboard and now have a 71 i/o with a 4 cyl merc (circa 89).
The I/O rides better, gets better economy, cruises a little slower and tops out a couple miles per hour less... any day my family and I would rather have the IO. We actually like the IO box, it's great for sitting on while drift fishing, and the closed transom is nice...especially with a 1 and 3 year old. It's the best, most capable all around boat for us I feel like we could find anywhere.
Old 07-09-2010, 09:13 AM
pelican pelican is offline
outboards-only power designed strictly for marine use,anything else,is an after thought-hence,the term,"marinization"
stern drives,nothing wrong with a stern drive-my rig's stern drive powered-merc 5.7 magnum mpi with the horizon package and a bravo I drive-230 trouble free hours in 2 seasons-fantastic on fuel ! there's a little more upkeep on a stern drive boat-risers and manifolds every 4-5 seasons,pull the drive every winterization,30hr oil changes...but,it's got it's benifits,quieter,much quieter...engine box ?? not in the way at all,it's a center console,you fight a fish from the bow...
ride is better on a stern drive,but,the inboard has the best ride-low center of gravity...outboards on a bracket are the worst ride-leverage.the engine's sitting way behind the boat,acts as a lever,the boat has a tendency to porpoise,and ride "bow high",need alot of "down tab" to counter act...
Old 07-09-2010, 06:22 PM
Come ride on mine, I honestly don't get what most people expect their boat to do or how they expect to run them. These are small boats and a I/0 or inboard at any real speed in any sea condition worth talking about usually doesn't come close to an outboard. I have spent extensive time on 20sf's like mine. I/o, outboard, and bracketed. My and the two other bracketed boats I have spent time on far exceed the ride and capability at speed of an outboard on the transom or I/o. I just have a foil on it no tabs and no porpousing.
Old 07-09-2010, 08:19 PM
Let's be honest for a moment.
If you are looking for braggin' rights regarding WOT speed you'll probably favor an OB and maybe a bracketed OB with the cav plate 1.5 inches above the keel.
If your looking for a bit quieter engine noise at a lower less irratating pitch and are willing to give up 12-16 square feet of cockpit space that can double as a seat/"cocktail" table/ casting platform/ baiting station/ sundeck, with better fuel economy and a more "solid" ride, then you're going to favor an I/O. (guess which side I'm on?)
The reality is that this is why they make chocolate and vanilla!
Regarding speed I just did a quick calculation. If the distance is 20 miles and an O/B WOT speed is 43, then you get there in about 28min., if your WOT on an I/O is 39 then 20 miles is about 31min.
My question is: Whose wife has gotten mad at them for being only 3 minutes late getting home from a fishing trip?
Just a thought!
Plan accordingly!
