Old 07-14-2010, 10:25 AM
Cbreezer Cbreezer is offline
Default Re: FOR SALE: 1980 SeaCraft CC with 1995 200HP Yamaha
The engine runs well and has been properly serviced every year. The gauge with the tach leaks and needs to be replaced. The power tilt switch on the throttle handle only works in one direction (down), Up must be operated with the switch on the engine. (I'm sure it's just a bad switch on the throttle). The Yamaha 200 is a good solid engine and has worked well since I bought it new in 1995.
The deck hatches and transom were worked on, before I bought the boat in 1995. All seems to be OK but there are some surface cracks visible. There is a repaired area on the bow where we met a pole one night. I will send more detailed photos of this if you are seriously interested in the boat.
No Trailer.
She's in the water and running fine.
